It is currently Sun Jul 20, 2025 9:20 pm
PostPosted: Tue Jan 16, 2007 6:27 am
State: ON
I just had a phone message from someone who said they wanted me to clear coat over a signature on their guitar. I don’t know who signed it or what kind of marker was used. Can I spray nitro over a signature without the ink running? If anyone has done this I would appreciate some advice.
josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Tue Jan 16, 2007 6:41 am
Be aweful careful Josh! It will probably work as long as the nitro is not allowed to run. Most markers are alcolhol based and lacquer thinner is a great way to remove them from unwanted, kid installed, locations. Try it on some scrap and see what happens, lay down a couple of coats, sign your name and then clear over it.
Good Luck!
ShaneShane Neifer39098.6126273148
PostPosted: Tue Jan 16, 2007 9:06 am
Depending what and where it is .. put a clear piece of mylar pickguard over it ..
2 things - the signature might run - or who knows what the underlying finish is, and whether anything will really stick to it for any length of time.
PostPosted: Tue Jan 16, 2007 11:35 pm
State: ON
Tony,
I like that idea! I think the guitar is a fairly cheap electric and I have no idea what the finish would be. The pickguard idea would probably be the easiest solution.
Josh House
PostPosted: Tue Jan 16, 2007 11:44 pm
If its a cheap electric, its not likely nitro, likely poly of one sort, and nitro wont stick that well, especially if you cant rough it up.
PostPosted: Wed Jan 17, 2007 4:19 am
First name: Martin
Last Name: Edwards
clear pickguard mylar from stewmac sounds good
